**PATRIOT INTEL MASTERS MEMORY RANGE EXPANSION AND A CRAZY DEAL!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right guys, we've massively expanded the Patriot Intel Masters range of truly awesome memory, check them out below and remember they are on THIS WEEK ONLY so take advantage of the great prices:-
Patriot Intel Extreme Masters 16GB (4x4GB) DDR3 PC3-17000C11 2133MHz Quad Channel Kit (PVI316G213C1QK) @ £95.99 inc VAT
The Intel® Extreme Masters (IEM) Memory, a limited edition kit designed with true performance and gamers in mind. These modules are hand tested and compatible with the latest Intel® DDR3 platforms to ensure stability for the most intense gaming environments. The Intel® XMP Certification ensures a seamless gaming upgrade and experience.
The Intel® Extreme Masters, Limited Edition utilizes the Viper 3 variation design for its heat dissipating capabilities for superior performance to ensure rock solid stability even when using the most taxing applications. Built with the highest quality of components, we back our memory with a lifetime warranty.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s IEM Edition will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts. This exclusive memory by Patriot Memory will only be available during Season 7 show of IEM. Visit www.intelextrememasters.com for more information.
Features:-
- Extreme Performance PC3-17000 (2133MHz)
- Low Latency (11-11-11-27)
- Voltage: 1.50-1.60V
- XMP Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel 6 & 7 series platform
- Lifetime Warranty
Was [£107.99] Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 32GB (4x8GB) DDR3 PC3-14900C10 1866MHz Quad Channel Kit (PVI332G186C0QK) @ £167.99 inc VAT
Features:-
- Extreme Performance PC3-14900 (1866MHz)
- Low Latency (10-10-10-27)
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
Was [£211.99] Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 16GB (4x4GB) DDR3 PC3-14900C9 1866MHz Quad Channel Kit (PVI316G186C9QK) @ £77.99 inc VAT
Features:-
- Extreme Performance PC3-12800 (1866MHz)
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
Was [£101.99] Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 32GB (4x8GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (PVI332G160C9QK) @ £149.99 inc VAT
Features:-
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (9-9-9-24)
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
Was [£199.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (PVI316G160C9QK) @ £79.99 inc VAT
Features:-
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
Was [£89.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 16GB (2x8GB) DDR3 PC3-14900C10 1866MHz Dual Channel Kit (PVI316G186C0K) @ £79.99 inc VAT
Features:-
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
ORDER NOW
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (PVI38G186C9K) @ £37.50 inc VAT
Features:-
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
Was [£44.99] Inc. VAT
Only £37.50 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI316G160C9K) @ £71.99 inc VAT
Features:-
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
Only £71.99 inc VAT.
ORDER NOW
AND NOW FOR OUR CRAZIEST DEAL EVER ON SOME OF THE HIGHEST AND BEST LOOKING MEMORY OUT THERE:-
Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) @ £23.99 inc VAT
Patriot Memory’s Viper 3 Series memory kits are designed with true performance in mind. Tested and compatible with Intel’s® and AMD’s DDR3 compatible processors and chipsets, The Viper 3 series provides the best performance and stability for the most demanding computer environments.
The Viper 3 series utilizes a custom designed high performance heat shield or superior heat dissipation to ensure rock solid performance even when using the most taxing applications. Built from the highest quality Build of Materials, Patriot Memory’s Viper 3 Series memory kits are hand tested and validated for system compatibility.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s Viper 3 Series will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts and are XMP 1.3 eady. Hand tested for quality assurance, the Viper 3 series is backed by a lifetime warranty.
- Voltage: 1.5v
- XMP 1.3 Ready
- RoHS Compliant
- Tested on Intel® P67 and Z77 platform
Was [£31.99] Inc. VAT
Only £23.99 inc VAT - THIS PRICE ENDS 18:00 TODAY!!!
ORDER NOW
Remember guys Patriot is uses pretty much absolute best quality components across their Viper and Intel Master range, its why afterall they are allowed to build RAM for both Intel and AMD. :)
Also all Patriot RAM uses black PCB, Gorgeous high-end heatspreaders and in general feature TIGHTER CAS TIMINGS than other competing brands.
"Remember guys Patriot is uses pretty much absolute best quality components" LOL!
Amazing price on the Patriot Viper 2 x 4GB :)
The Viper and IEM range do, were now building a lot of these parts because in our testing they have been superb.
Lets also remember Patriot also make the AMD approved memory too, if they were sub standard neither AMD or Intel would allow them to use their name on sub-standard products.
Yes Patriot offer some cheaper memory solutions, of which OcUK does not stock. :)
Just to clarify I quoted because I found the grammatical errors funny, I'm sure Patriot make very high quality products. :)
Sigh was out today and missed the deal :( oh well thinking of grabbing some 8GB sticks atm anyway, actually getting close to maxing out 16GB currently.
