PATRIOT SECTOR 5 VIPER II 4GB (2x2GB) PC3-18000 2250MHz MEMORY KIT @ £349.99 inc VAT
Suspended
18 Oct 2002
OcUK HQ
Available now we have our fastest Dual Channel memory kit. The Patriot Sector 5 Viper II 4GB (2x2GB) PC3-18000 2250MHz Dual Channel Memory Kit is available at £349.99 inc VAT.
Patriot Sector 5 Viper II 4GB (2x2GB) PC3-18000 2250MHz Dual Channel Memory Kit (PVV34G2250LLK) @ £349.99 inc VAT
The Patriot Viper II 'Sector 5' Series, part of the Extreme Performance (EP) Low Latency line, is the ultimate performance memory solution for the Intel P55 system platform. The Viper II 'Sector 5' series are built using only the highest quality pre-sorted IC's available and are subjected to rigorous testing and validation on the P55 platform to achieve optimized performance and maximum quality. These modules are engineered to reach PC3-18000 (2250MHz) at 9-9-9-27 timings and are available in 4GB kit capacity. Each module is 100% hand-tested for quality assurance and is backed by a full lifetime warranty and industry leading customer service.
- Extreme Performance PC3-18000 (2250MHz)
- Low Latency (9-9-9-27)
- XMP 1.2 Ready
- Voltage: 1.65V ~1.7V
- Equipped with advance aluminum heat-dispersing shields
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel® P55 chipsets
- Lifetime Warranty
Only £349.99 inc VAT.
ORDER NOW
It wasnt that long ago Geil Ultra oem kits 2133Mhz @ 9-9-9-24 were being sold at around £75 using Elpida BBSE ic's.
What's so different about these to warrant this price tag?
I'm guessing their Eplida Hypers that you usually see running at 2000Mhz @ 8-8-8-24 being tweaked.
I think RAM manufactures/retailers are pushing the limit with RAM prices now? This is just getting a tad silly haha. Awesome RAM, but then again, Kingston, OCZ, Corsair, G.skill and more are all coming out with RAM at these specs if not better. If they all try charging this much they won't get very far. I'm guessing the price is only high due to Patriot being the first ones out with this high spec RAM...
