Hi,
I've upgraded my ram from some hyper x fury 2666mhz to the ram listed above and now I'm trying to squeeze the most out of it using dram calculator but it doesn't seem too straight forward unfortunately.
My first issue is that I can't find some of the settings in the bios. I'm guessing they might just be called slightly different names?
My next issue is trying to work out if I should leave the FCLK on auto or use the ryzen calculator settings? I did up the FCLK to 1900 and it seemed to bench fine but I'm just not sure on the optimal settings.
Lastly is a question about frequency. I've read 3600 is the 'sweet spot' is this purely a bang for buck sweet spot or should I be dropping my dram frequency down to 3600?
Any help appreciated. I've attached a few screenshots to try and show what I've done.
Build is a b450 tomahawk max
Ryzen 3600 PBO enabled in bios
16gb (2x 8gb sticks) as above
Also, I only got a 200 point increase on time spy but I'm guessing that's probably about right?
Cheers
Cheers
