PAX PCI XFI ALL OS Driver V4.00
Caporegime
8 Sep 2006
On Ocuk
© Creative all rights be long to Creative and logos. Creative giving me there writing persimmon by Robert McClelland.
PAX related logos and software and drivers are own by PAX ®
- Please don't remod my work with out permission you can contact me at Hardwareheaven.com
Win7 – 32/64Bit - Read me
PAX
Performance Audio Xeleration
Tweaked Drivers for Creative Soundcards:
Better Performance. Better Audio. Better Xeleration.
“Tweaked Edition”
Supported cards:
Sound Blaster X-Fi XtremeGamer Fatal1ty® Professional Series
Sound Blaster X-Fi Platinum Fatal1ty Champion Series
Sound Blaster X-Fi XtremeMusic
Sound Blaster X-Fi XFI Xtreme Gamer Fata1ity pro
Sound Blaster X-Fi Fatal1ty
Sound Blaster X-Fi Elite Pro
Sound Blaster X-Fi OEM Elite Pro
Sound Blaster X-Fi
Soundblaster X-Fi OEM Cards: Dell, HP and Gateway
Setup should work with any XFI Card now!
ADD UHAA Main Driver
Supported OS:
Win7 32 and 64Bit
Based on:
SBXF_PCDRV_LB_2_18_0015
Fix DTS Nero PC in Creative Audio Control panel! Note not all Sound cards may carry this.
Fix Multi Channel for SPDIF Enable it fully works to get this you muss set at Stereo Surround and at 50% make full work.
Fix BSOD ha20x2k.sys ctexfifx.sys You should have no more blue screen of death. I put a lot testing into the drivers make them prefect enjoy them.
You have reinstalled PAX Master Suite v2.00 make work fully.
Full Support Win 7 enters That means I added support instead with vista it works with win 7 now.
I added Speaker Section reg to fix Creative console Section where you can choice your speaker setting.
You can find in main folder just click on it and installed.
I highly recommend used Iolo System Mechanic fix reg and defrag there free trial.
Important :
Before installing, remove all traces of any previous x-fi drivers and all x-fi driver by removing the driver within "Device Manager". To clean up any excess files left on your system, you should use a 3rd party program to do this job (unless you've a good understanding of the registry) A recommended program to do this is Driver Sweeper - which is freeware, and available from Guru3D - Driver Sweeper or paid version at hardwareheaven.com driver cleaner.net
To install the software driver :
Providing you've followed the steps above, restart your computer and run Setup.exe. Follow through the prompts until the installation has completed.
Please used register cleaner like tune up Advanced SystemCare iobit.com or crapcleaner
What is Pax?
Formally known as Youpax, Pax was founded by Robert McClelland 6 years ago, who is continuing to provide an alternative tweaked driver to the Official driver released by Creative.
Why should I install this Pax alternative?
Pax is aimed at improving sound quality and to give a more deeper bass sound, while retaining the clarity of the overall output audio. Most users continue to use Pax drivers once moving over and never look back!
http://www.hardwareheaven.com/pax-d...tive-download-section-mods-2.html#post1400416
PAX MASTER Suite V2.00
- XP/Vista/Win7 – 32/64Bit - Read me
PAX
Supported cards:
Auzentech Cards.
Sound Blaster X-Fi
Titanium and HD
USB Sound cards
Any other Sound cards?
Supported OS:
Fully working Suite for XP, Vista, Win7
32 and 64Bit
You can used this as mini suite for normal audio stuff.
PCI E Users is recommend used this Suite for now. To I fix the setup issue with the installer.
PCI users can also used this suite for those who don't have fast connection.
USB users can used this software too.
I can confirm that THX Console won't work on XFI Xtreme audio cards. How every you can used other stuff that listed.
Yes You can used on Xtreme Audio Notebook but THX Console won't work with it.
Auzentech users can used THX Console got info from a tester works 100% on it.
Please used register cleaner like tune up Advanced SystemCare iobit.com or crapcleaner Check Error for hard drive before installing.
Software Components:
Creative Console Launcher 2.61.53 New
Creative Audio Console 3.00.59 New
Creative Volume Panel 2.21.14 New
THX Console 3.50.08
Creative AutoMode Switcher 1.01.05
Creative ALchemy (X-Fi Edition) 1.43.06
Console and Panel from USB Pro software.
THX Console fully working now.
Rename the two files in THX console folder then it should work only way around it.
THXConsl.crl --> SpkConsl.crl
THXConsl.bff --> SpkConsl.bff
What is Pax?
Uninstall Clean EVERYTHING to do with creative, DriverSweeper/CCleaner making sure it doesn't try to reload any creative drivers again on reboot.
1) Install Driver
2) Install Suite
cant seem to get it to install after i clean using driver sweeper it reinstalls how do you get it to stop reintalling preivous drivers ?
Thanks for the headsup on these Neil, took the last revision driver off because of the bluescreen issues mentioned above. If these drivers have fixed that will give them a shot, as they do fix some of the bugs still present in creatives official offering.
New update soon, treble fix as with some creative drivers it's too high and causes crackle. Try the volume on 100% and see how long before it crackles with certain music.
Will post the update when it's available
