** PAYDAY DEALS - ROUND FOUR - GRAPHICS CARDS! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Once again check our THIS WEEK ONLY PAGE for some truly great deals, but were also offering the following as well:-
XFX ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card with FREE MOH & Stalker Games **PRE-ORDER ONLY PRICE** @ £113.99 inc VAT
With the 6000 series, XFX is literally putting you in the game. The AMD Radeon HD 6850 is 3-D ready and one of the first HDMI 1.4a and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market.
The AMD Radeon HD 6850 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost.
This high-speed graphics card outdoes the competition with 775MHz, a 4 GHz memory clock, DP + HDMI + Dual DVI which allows for play across four screens and a shader speed of 800 to ensure that graphics are crisp and life-like.
Along with the new series XFX debuts the 3E Trilogy, incorporating AMD Eye-Definition (utilizing AMD’s HD3D technology & DirectX 11 for explosive performance and stunning effects), AMD Eyefinity (which supports multi-display gaming) and AMD Eyespeed (improves video image quality and application performance for amazing visuals) technologies.
The AMD Radeon HD 6850 offers no compromise performance with flawless image quality so users aren’t just playing the game – they’re in it.
- Core Clock: 775MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: ?
- Processing Cores: 960
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1x DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
- Supplied with FREE Download of Latest Medal of Honor & Stalker PC-Games when you register product with XFX, see inside packaging for download instructions
Was [£124.99] Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 580 3072MB GDDR5 PCI-Express Graphics Card @ £399.98 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 783MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Uprated quiet cooling solution
- Memory: 3072MB GDDR5
- Memory Clock: 4020MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1566MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
Was [£449.99] Inc. VAT
Only £399.98 inc VAT.
ORDER NOW
OcUK GeForce 9800 GT 512MB GDDR3 PCI-Express Graphics Card - OEM @ £37.99 inc VAT
- Ideal for PhysX!
- Core Clock (MHz): 550 MHz
- Processor Cores: 112
- Processor Clock (MHz): 1375 MHz
- Fill Rate (billion pixels/sec.): 30.8
- Memory Amount: 512MB GDDR3 On-board Frame Buffer
- Memory Frequency (effective): 1800 MHz
- Memory Interface: 256-bit
- Memory Bandwidth (GB/sec): 57.6
- On-board Outputs: DVI-I and DVI-I
- Additional Outputs Supported: HDMI, VGA
- BUS Technology: PCI Express 2.0
- 1yr Warranty with OcUK
- This is a refurbished fully functional product, it may have minor visual defects and is just a bare card, no cables, drivers etc.
Only £37.99 inc VAT.
ORDER NOW
Quick question on the OcUK GeForce GTX 580 3072MB GDDR5 PCI-Express Graphics Card @ £399.98 inc VAT. Will that SLI with any other GTX580 even if its a 1536MB model? Reason I ask, I have 2 Zotac GTX580's 1536MB and was planning to put 1 of them in another PC and upgrade with the OCUK 3072MB model, but I want to make sure I will still get the full benefit of SLI & the extra memory for running at 2560x1600?
Edit: on a side note, is the extra memory on the above card only useful for running graphics at a higher resolution then 1920x1200? Or does it have other benefits as well?
if you can sli the 3gb one with the 1.5gb you only get 1.5gb of the ram usable per card so half will go to waste on the 3gb. not an expert so can't tell you if it'll work, but have read people say you 'loose' half the vram on the 3gb version(same thing if you were to xfire a 1gb 6950 with a 2gb 6950).
Dang. I'd get that 6850 if I wasn't already spending money on my missus' birthday presents :p
Also, is the 6850 able to outperform say the 4870X2? And can it be flashed to 6870 or has that been totally scrapped these days?
According to Nvidia you can't SLI cards with differerent memory sizes.
Can I mix and match graphics cards with different sizes of memory?
No. For example, an XXXGT 512MB cannot be paired with a XXXGT 1GB in an SLI configuration.
Nvidia SLI FAQ
if you're thinking about the xfx 6850 you're better off going for the £120 6870 in another thread.
