Hi there
More great deals to finish off the day on monitors:-
Dell ST2220M 21.5" Widescreen LED Monitor - Black @ £99.98 inc VAT
Take your multimedia viewing experience to another level with the ST2220M full HD monitor with LED. This 54.61cm (21.5") widescreen display is an optimum choice for cinematic quality and makes watching movies, playing games and photo editing an amazing experience.
The new Dell™ ST2220M 54.61cm (21.5") widescreen full HD monitor with LED delivers true cinematic picture quality with a 16:9 aspect ratio and excellent color contrast (estimated dynamic contrast ratio of 8,000,000:1). Give your movies, videos and games the big-screen attention they deserve with clear 1920 x 1080 full HD resolution and true-to-life picture quality. Plus, add the optional Dell multimedia soundbar for even more enhanced audio performance.
With its slim depth and high-gloss front bezel that complements your desktop, the ST2220M is a stylish monitor designed to fit most home environments. Elegant, functional and built for maximum comfort, its tilt-adjustability feature has a panel tilt of 4° forward and 21° backward. You’ll also be amazed by the intuitive touch controls and the beautiful lit bottom front bezel when the monitor is on.
The ST2220M monitor was designed for the environmentally conscious user. This highly efficient LCD panel is both mercury and arsenic free. The LED backlight complies with the stringent environmental standard, ENERGY STAR 5.0, to help you lower energy consumption without sacrificing performance.
Enjoy the convenience of digital and analog connectivity options. Seamlessly connect the ST2220M to your desktops, laptops and gaming consoles with DVI (HDCP) and VGA analog ports. Cables sold separately.
- Screen Size: 21.5" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 8,000,000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D
- Weight: 7.65kg
- Warranty: 3 Years Next Day Swap Out Warranty Direct from Dell.
Was [£109.99] Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
OcUK V-Line 221V2SB 22" Widescreen LCD Monitor - Black @ £79.99 inc VAT
You want the LCD flat display with the highest contrast and most vibrant images. Philips advanced video processing combined with unique extreme dimming and backlight-boosting technology results in vibrant images. SmartContrast will increase the contrast with excellent black level and accurate rendition of dark shades and colours. It gives a bright, lifelike picture with high contrast and vibrant colours.
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc with the mouse.
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colours.
With sustainability as a strategic driver of its business, Philips is committed to using eco-friendly materials across its new product range. Lead-free materials are used across the range. All body plastic parts, metal chassis parts and packing material uses 100% recyclable material. A substantial reduction in mercury content in lamps has been achieved. We strictly adhere to RoHs standards which ensure that all hazardous material is removed.
On-Off response time is the period required for a liquid crystal cell to go from active (black) to inactive (white) and back to active (black) again. It is measured in milliseconds. Faster is better: lower response time means faster transitions and, therefore, results in fewer visible image artefacts in the display of transition of texts and graphics. On-Off response time is a more important measure in the display of business content like documents, graphs and photos. This monitors sports a 5ms ON/OFF response time making its grey-to-grey response time 2ms.
Adjustable tilt is backward and forward movement of a screen on its base to achieve custom positioning for an ideal viewing angle and more comfort for people who spend long hours working on the computer.
Philips easy picture format control on OSD switches from the 4:3 aspect ratio to the widescreen mode and back again to match the display's aspect ratio with your content; it allows you to work with wide documents without scrolling or viewing widescreen media in the widescreen mode and gives you distortion-free, native mode display of 4:3 ratio content.
Philips designs and produces display products in compliance with strict Restriction of Hazardous Substances (RoHS) standards that restrict lead and other toxic substances that can harm the environment.
Features:-
- LCD panel type: TFT-LCD
- Panel Size: 21.5 inch/54.61 cm
- Aspect ratio: 16:9
- Pixel pitch: 0.248 x 0.248 mm
- Brightness: 250 cd/m²
- SmartContrast: 300,000:1
- Response time (typical): 2 ms
- Inputs: 1x Analogue & 1x DVI-D
- Optimum resolution: 1920 x 1080 @ 60 Hz
- Viewing angle: 176º (H)/170º (V), @ C/R > 5
- Display colours: 16.7 M
- Scanning Frequency: 30–83 kHz (H)/56–75 Hz (V)
- sRGB
- 3yr On-Site Warranty
Was [£99.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Dell Ultrasharp U2311H 23" Widescreen LCD Monitor - Midnight Grey @ £214.99 inc VAT
Your profession, your passion: No matter how you use your computer, the Dell UltraSharp U2311H 23" (58.42 cm)W Monitor brings your visuals to life in stunning widescreen clarity.
- Screen Size: 23" Widescreen
- Contrast Ratio: 10000:1
- Brightness: 300cd/m²
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Inputs: 1x Analogue, 1x DVI-D & 1x DisplayPort + USB 2.0 Hi Speed Hub.
- Dimansions: 514.40mm x 184.10mm x 347.60mm
- Weight: 7.65kg
Was [£239.99] Inc. VAT
Only £214.99 inc VAT.
ORDER NOW
Dell UltraSharp U2412M 24" Widescreen LED Monitor - Midnight Grey @ £289.99 inc VAT
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style. Powerful:
- Experience IPS technology, featuring a wide viewing angle with high-quality color representation for a peerless viewing experience.
- Flexible: Pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
- Customizable: Change your energy usage settings, text brightness and color temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel.
Whether for work or for play, the Dell UltraSharpTM U2412M can deliver an unmatched viewing experience.
- Clearly outstanding: Watch your graphics come to life on a vast 24" (61cm) LED-backlit screen featuring a crystal-clear 1920x1200 resolution on a 16:10 widescreen aspect ratio so you can’t lose screen area just because your customized applications support a different resolution.
- Contrasting view: Get ready for blur-free viewing with 2 million:1 (typical) high dynamic contrast ratio and 8ms with overdrive gray-to-gray (typical) response time that helps ensure crisp, sharp and ghost-free images.
- Colorful character: Enjoy an amazing range of rich, dramatic and accurate colors, thanks to IPS technology designed to give you color consistency across a broad viewing angle and a wide color gamut at 82% (typical).
- Premium Panel Guarantee: 100% replacement of Dell UltraSharp series monitors sold if any bright pixel is found, valid within the warranty1 period.
Specification:-
- 24" (60.96 cm) viewable area
- Widescreen (16:10)
- Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
- 1920 x 1200 at 60 Hz
- 1000 : 1 (typical)
- 2,000,000:1 (dynamic)
- 300 cd/m2 (typical)
- 8ms (gray to gray) Typical
- 178º / 178º
- 16.7 million colors
- Color Gamut: 82% (CIE 1976)
- 0.27 mm
- 1x Digital Visual Interface connectors (DVI-D) with HDCP
- 1x DisplayPort(DP)
- 1x Video Graphics Array (VGA)
- 1x USB 2.0 upstream port
- 4x USB 2.0 downstream ports
- DC power connector for Dell Soundbar
- Height-adjustable stand, tilt , swivel , pivot and built in cable-management
- Flat Panel Mount Interface
- VESA Mount
- Warranty: 3 Years On-Site (Dell Premium Guarantee - You will receive a replacement UltraSharp monitor should even one bright defective pixel appear on the screen)
Was [£299.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
IIyama Prolite X2472HD 24" Premium VA Panel Widescreen LED Monitor - Black @ £149.99 inc VAT
ProLite X2472HD - a 24” LED backlit LCD Screen featuring VA Panel technology offers superb colour performance and amazing viewing angles. Offering 24 bit ‘True Colour’ and great performance for displaying Black and White with the 3000:1 Native Contrast Ratio, means that the Prolite X2472HD will provide excellent performance for Photographic, Design and Web-design. Featuring a fast response full HD 1920 x 1080 Display with VGA, DVI and HDMI connectivity this screen ensures compatibility with a wide range of systems and applications. With the added support of a Low Power LED Panel, the iiyama Prolite X2472HD is an excellent choice for Universities, Corporate, Financial and Design Markets.
Features:-
- Diagonal: 24"
- Panel: VA, LED-Backlit
- Display area: h x w 298.9 x 531.4 mm; 11.8" x 20.9"
- Response time: 8 ms
- Contrast: 3000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 250 cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour: 24-bit, 16.7 million
- Pixel pitch: h x v 0.277 x 0.277 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 30 - 75 KHz
- Vertical sync: 55 - 70 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- Analog input connector: D-Sub
- Digital input connector: DVI-D, HDMI
- HDCP: yes
- Output connector: Audio out (only with HDMI input)
- 3yr Warranty
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
AOC E2795VH 27" Widescreen LED Monitor - Black @ £214.99 inc VAT
No compromises: The e2795Vh is perfect for office and action. This Full HD large-screen monitor with integrated speakers not only looks fantastic. The generous 16:9 display area offers ample space for complex charts, double-page spreads, image editing, games, videos or movies. High contrast and brightness values in combination with wide viewing angles and a fast response time provide an excellent image quality without blurring from almost every perspective. Thanks to DVI-D and HDMI inputs (with HDCP) high-resolution content from numerous video sources is displayed flawlessly. With electricity-saving LED backlights and a mercury-free manufacturing this flatscreen is also easy on the environment.
Features:-
- Screen Size: 27" Widescreen
- Contrast Ratio: 20,000,000:1
- Response Time: 2ms
- Contrast Ratio Typical 1.200:1
- Pixel / Dot / Pitch 0.3114 (H) x 0.3114 (V)
- Display Area 597.6 (H) x 336.15 (V)
- Special Features: DCB,e-Saver,i-Menu,Kensington Security Lock,screen+,SRS,USB,Wide View Angle
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
Was [£229.99] Inc. VAT
ORDER NOW
Dell UltraSharp U2711 27" Widescreen LCD Monitor - Midnight Grey **1yr Warranty** @ £494.99 inc VAT
With its amazing colour accuracy and versatile connectivity, the high-performance Dell U2711 Monitor delivers stunning detail, depth and responsiveness. PremierColour technology allows the Dell U2711 Monitor to deliver reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. Factory-tuned Adobe RGB and sRGB modes minimize the need for further colour calibration; each monitor arrives with a certified colour-calibration factory report. 100% sRGB and 96% AdobeRGB meets the needs of professional users involved in colour-centric work such as graphic design, CAD/CAM, gaming and media creation.Customize your viewing experience with the height-adjustable stand and tilt/swivel features - or save valuable desktop space by detaching the panel from the stand for wall mounting.
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 80000:1
- Brightness: 350cd/m²
- Response Time: 6ms
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 2x DVI-D, 1x HDMI, 1x DisplayPort, 1x Composite & 1x Component
- 4-Port USB Hub
- 8-in-1 Card Reader
- VESA Compliant
- Dimensions: 646.71mm x 427.83mm x 199.95mm
- Weight: 7.72kg
- Warranty: 1 Year Return to base (OcUK)
Was [£539.99] Inc. VAT
Only £494.99 inc VAT.
ORDER NOW
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black @ £233.99 inc VAT
The Hanns.G 27.5" has an industry ultra-fast 3ms response time making it perfect for blur-free video and gaming. With it's 15000:1 contrast ratio and excellent viewing angles there is no other TFT that can match the combination of quality, value and performance. Making the large screen affordable to all this 27.5" is ideal for gamers and home cinema use due to its huge size and 1920x1200 resolution.
- Screen Size: 27.5" Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 15000:1
- Brightness: 400cd/m²
- Response Time: 3ms
- VESA Compliant
- Dimensions: 653.0mm x 523.0mm x 254.0mm
- Weight: 8.5kg
Was [£249.99] Inc. VAT
Only £233.99 inc VAT.
ORDER NOW
- Weight: 7.65kg
ORDER NOW
Features:-
- sRGB
ORDER NOW
- Weight: 7.65kg
ORDER NOW
Specification:-
- 178º / 178º
- 0.27 mm
- VESA Mount
ORDER NOW
Features:-
- Diagonal: 24"
- HDCP: yes
- 3yr Warranty
ORDER NOW
Features:-
- VESA Compliant
ORDER NOW
- Height Adjustable
- 4-Port USB Hub
- VESA Compliant
- Weight: 7.72kg
ORDER NOW
- VESA Compliant
- Weight: 8.5kg
ORDER NOW
