** PAYDAY DEALS - ROUND TWO - CASES! **
rjk
rjk
OcUK Staff
8 Aug 2007
More deals for today, plenty of deals to be had on some of our most popular cases :D
Fractal Design Define R3 Midi Tower Case - Black Pearl @ £69.59 inc VAT
The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The patent pending feature ModuVent™, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 8 white painted HDD-trays, with silicone mounting
- A total of 7 fan slots (2x120mm in front, 2x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120/140mm in bottom)
- 2x 120mm Fractal Design 120mm fans included
- Fan controller for 3 fans included
- Easily removable front fan filters with clip-on holders for 120mm fans
- Supports graphic card lengths up to circa 290mm and CPU coolers with height of maximum circa 165mm
- 1 rear Fractal Design 120mm @ 1350rpm included
- 1 front Fractal Design 120mm @ 1350rpm included
- 1 front 120mm fan (optional)
- 1 bottom 120mm/140mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
- 2 top 120mm/140mm fan (optional)
- Case size (WxHxD): 207.4 x 440 x 521.2mm
Improvements from R2
- Improved air flow with updated fans
- Improved noise absorbing material
- Bigger hole in M/B plate for mounting of CPU Coolers
- Improved cable routing possibilities
- Reset button, located behind the front panel door
- Many small quality improvements, including improved scratch resistant coating
Was [£79.99] Inc. VAT
Only £69.59 inc VAT.
ORDER NOW
Silverstone Precision PS03B Midi Tower Case - Black @ £38.39 inc VAT
For SilverStone engineers, innovation is more than feature improvements; it is about improving total user experience. The Precision series PS03 is designed for users that appreciate quality computing experience and maximizing performance and utility. It has an amazing two 120mm fan slots and one 120mm/140mm fan slot for users to tune and tweak for the best possible cooling arrangement that suits each assembled system. A door on top of the case hides a tray area that gives users extra room to conveniently place any small items or accessories. For those requiring a quality enclosure with great styling and flexibility, the PS03 is an excellent choice.
- Mesh front panel and steel body
- Dimensions: 200mm x 472mm x 471mm
- Motherboard Compatible: MicroATX & ATX
- 5.25" Drive Bays x 4
- 7 x 3.5" Drive Bays
- Front Cooling: 1 x 120mm fan (optional)
- Rear Cooling: 1 x 120mm fan
- Top Cooling: 1 x 120mm fan (or optional 1 x 140mm)
- Front I/O Ports: USB2.0 x 4, Audio x2
- Expansion slots: 7
Was [£41.99] Inc. VAT
Only £38.39 inc VAT.
ORDER NOW
Antec 300 Three Hundred Ultimate Gaming Case - Black @ £44.99 inc VAT
Impressively spacious and unbeatably reliable, the Antec Three Hundred is an unbeatable enclosure. Despite its eminently portable frame, the Three Hundred has enough room for all the latest flag-ship graphics cards, as well as six hard drives and a standard ATX motherboard. A cable management compartment keeps your system organized and the airflow unobstructed. A 120mm rear fan and 140mm top fan ensure that the case runs cool even when playing the most demanding games, while the sleek black finish gives it an extra stylish edge.
- External 3 x 5.25"
- Internal 6 x 3.5" for HDD
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
Was [£51.98] Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Cooler Master HAF X Gaming Tower Case - Black (RC-942) @ £133.98 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2 (1 included)
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1 (not included)
- VGA Holder: 80 x 15mm fan x 1 (not included)
- PCI Slots: 9
- Bottom mounted PSU
Was [£145.99] Inc. VAT
Only £133.98 inc VAT.
ORDER NOW
Corsair Graphite 600T Midi Tower Case - Limited Edition White @ £119.98 inc VAT
The Graphite Series™ 600T makes it easy to build a world-class gaming system. With excellent cooling from the dual 200mm fans, eight PCI-E expansion slots to accommodate multiple graphics cards, and plenty of room for large, power-hungry components, the Graphite Series 600T can handle just about anything you can throw at it.
The Graphite Series 600T is a mid-tower in height, but inside it’s positively cavernous. Easily accommodate even the longest graphics cards in the industry due to the reconfigurable hard drive bays. The increased space behind the motherboard tray allows clean, uncluttered cable routing. Up to six hard drive caddies, each of which can accommodate SSDs and standard mechanical disks, sit below the four 5.25" tool-free optical drive bays. If that weren’t enough, you can remove the top panel 200mm fan and install a 240mm radiator and dual 120mm fans for a quick watercooling upgrade. The Special Edition White 600T also includes a new custom side panel with a cutout for a window (pre-installed) or included mesh insert with room for up to four 120mm fans for even more outrageous cooling!
Corsair innovated cable routing with the Obsidian Series™ cases, and the Graphite Series features the same ingenious design. Pre-cut holes in the motherboard tray with rubber grommets and plenty of room behind the motherboard to route cables for a clean, uncluttered interior. The optical drive bays are tool-free, the side panels easily detach with the built-in latch mechanisms, and the integrated fan controller allows you to choose between quiet operation or maximum cooling performance.
- Twin 200mm cooling fans with white LEDs for excellent cooling
- Side panel with cutout for window AND mesh with room for four 120mm fans - both included!
- Eight expansion slots provides you flexibility for multiple graphics card solutions
- Unique cable routing holes guarantees you a clean and clutter-free installation
- Integrated fan controller, for up to four fans, gives you the choice of noise vs. performance
- Tool-free optical drive installation makes building your system faster than ever
- CPU backplate cutout makes upgrading your CPU heatsink easy
- 2.5” and 3.5” hard drive compatibility for up to 6 drives — straight out of the box!
- Two year warranty with Corsair’s world-class customer service and technical support
Was [£139.98] Inc. VAT
Only £119.98 inc VAT.
ORDER NOW
do they still make cases with removable motherboard trays? I have an akasa eclipse which has and that's my favorite case of the 3 I've had over the last 5yrs(akasa eclipse, coolermaster cosmos s v1(wishing I never bought it, didn't like it when I 1st saw it in the flesh but it grew on me and I ended up getting it) and lian li a05).
