If I wanted to add some future proofing to my Ethernet cabling by also including provision for adding a PBX at a later stage...
I currently have a secondary master socket / NTE5 which is wired from 2 & 5 of my external master / XTE to the AB of the NTE5. This provides a filtered adsl connection via a vdsl filter interstitial face plate.
Should I run a Cat6 cable from the patch panel upstairs to the XTE or daisy chain from the NTE5 as an extension?
Is there a PBX faceplate that fits to the lower half of an NTE5, i.e. so it doesn't connect to the test socket, but rather can be wired to the patch panel and then to an extension port on a PBX?
If there isn't an NTE5 style PBX lower half faceplate does the NTE5 just become an adsl socket only and I would then be best to put a blank plate on the lower half?
It would be nice to make use of the NTE5 lower half for PBX as it would save having to use a CAT6 port on a nearby faceplate for telephony.
Do I need a special patch panel or do all patch panels do both voice and data?
