I think this has probably been asked before, but I dont know what I would type to find it in a search.
Anyway, I just looked through 20 pages of the "Post your 360 setup thread" (boredom
) and a lot of you have your 360 hooked up to your PC screen. Now I have the same cable that does this and I tried it and it works, but I want to know if those that use their PC screen for their 360 unplug their PC cables and replug their 360 ones in for video and sound like I do or do they use some sort of switch to make it easier?
This would make life easier for me if someone can point me in the right direction on how to set up a switch to make swapping between my PC and 360 easier using my PC monitor and speakers.
Thanks.
) and a lot of you have your 360 hooked up to your PC screen. Now I have the same cable that does this and I tried it and it works, but I want to know if those that use their PC screen for their 360 unplug their PC cables and replug their 360 ones in for video and sound like I do or do they use some sort of switch to make it easier?This would make life easier for me if someone can point me in the right direction on how to set up a switch to make swapping between my PC and 360 easier using my PC monitor and speakers.
Thanks.
