PC @ 4k/uhd low or medium settings vs console?
1 Apr 2014
Aberdeen
On my A770 4k medium settings looks pretty damn good and I get about 60 fps. Easily good enough to play. Excluding RT, obviously. How does this compare with consoles? Can a RX 6600, RTX 3050, or A750 match or better a PS5 or new Xbox at 4k?
The closest GPU we have to the PS5 is the AMD 6650 which will give you similar if not identical experience.
The GPUs you mention are a bit slower than the PS5 especially the A750 but I don't expect the downgrade to be that noticeable if you match console settings and resolution.
