pc-7+ and scythe ninja
Permabanned
31 Dec 2006
Ol' Ballymoney
ok i have a lian li pc-7+ and a scythe ninja plus, could people please tell me what is the best way to have the heatsink and fans round? also need ne case fans (broke them lol). pics would be much appeciated
Cheers
-Nick-
I have the Fan facing the Hard Drives/CD Rom. It all depends on the airflow of your case really. Ill try and post some pics later when i finish work.
Hi, has the case a fan at the rear, if so you should have the fan on the ninja on the opposite side of the heatsink so it blows across it and out of the case...
ChrisC
hi, a friend of mine is planning on getting the PC-7+, however is thinking about a Enermax Galaxy PSU. Are these compatible size wise?
many thanks!
i would have the set up like this, im sure Yewen would say the same thing.
any hot air rising will be taken out by your PSU and top 80mm fan if you
have 1 installed.
