pc a bit sluggish
10 Nov 2011
Telford
just built this pc from scratch and don't know if its just me on my system with an SSD but it just feels a bit sluggish.
CPU: Athlon 750K
RAM: Ballistix 4GB 1600mhz
Mobo: MSI A55M-E33 AMD A55 Chipset (Socket FM2) DDR3
HDD: Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache
GPU: Sapphire R7 260X OC 2GB GDDR5
Its currently running on the stock AMD fan but something does seem to get very noisy once games have been playing for a while.
Would chucking a 128GB SSD make that much of a difference in the feel of the system (Not ran without an SSD for years now)?
Anything else you can recommend to make it a bit more responsive?
Will take a look at whats running in the background when I get home
ssd would help a lot in windows
if its windows 8 you might be hitting swapfile a lot
id set a fan profile on the gfx card if that not quiet it down any get a cheap cpu cooler ><
ordered a chap 64GB SSD for windows and applications.
Yes its running windows 8.1
will take a look at the fan profile.
Any ideas on a cheap ATX - Micro ATX case that has decent airflow?
duno dont see much new like that
silverstone matx keep get cheaper they good
or could get a budget one and put couple extra fans in
like a zalman or something
Have a look at this case - Raijintek Agos Midi Tower - Black £39.99
Agos is the revolutionary new Mid Tower chassis from Raijintek. Developed in cooperation with German Designers and
engineers, the Agos is innovation paired with classic design.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-001-RT&groupid=2362&catid=2850
looks good got it down to
YOUR BASKET
1 x Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW) £44.99
1 x Raijintek Agos Midi Tower - Black £39.95
1 x Silverstone Redline RL01 Gaming Case - Black (SST-RL01B USB 3.0) £29.99
Total : £127.22 (includes shipping : £10.25).
WHy do people order 64gb ssd I mean really windows is about 50gb in and fully updated, min id use is a 120 and even then that is MIN you can get a 250gb for like 70 or 80 quid now.
Amd stock coolers are loud get a after market one
windows 8 only takes up 30GB and its for my sons PC so its only going to have Windows, office and antivirus on the SSD. It also cost me £30 incl delivery.
Was looking at an aftermarket cooler as well.
i think this 1 looks rly good value
http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-RT&groupid=2362&catid=2850
pre-order tho :(
looks like it has good dust filter which is important, i duno tho never seen them before
and i agree 64gb ssd is better than no ssd, should help a lot with keeping windows fast
if you need a couple cheap fans i can recommend these
http://www.overclockers.co.uk/showproduct.php?prodid=FG-029-AR&groupid=701&catid=2331&subcat=4
they rly very quiet, used one on a gfx card before
