PC-A05NB question
You should have no problem fit perfectly into the case and still got a bit of room left.
A bit of warning, monitor your system tempt because the cooling is terrible with this case.
After cutting the top panel to exhaust the hot air out, I shaved off 10C off my system temp.
My gtx 580 would reach 85-90C while playing bfbc2 without 2 top exhaust fans.
As has been said I would definitely fit some form of cooling up in the top corner, either a PCI blower or one of the Lian Li jobbies, or even by modding the top panel, as there is a hot spot in that space.
Thanks, I have been reading a few threads and notice the cooling was poor but it's just the size i'm looking for.
You could do a nice front panel mod :).
(Not my mod and from another site).
