PC acting strange?
Permabanned
21 Jan 2012
Doncaster
I'm not sure whats going on with my PC.
Speedwise it's as quick as ever, however certain things are not working. My AMD Catalyst doesnt load, when I click library on steam the program closes and when I click to play wow, it says game is running then nothing.
I'm baffled.
Remove any overclock from CPU, RAM and GPU.
Try deleting and recreating the Paging File - http://www.sevenforums.com/performa...sys-hiberfil-sys-delete-safe.html#post1731907
Shut down and unplug power cord from PC and remove and re-insert RAM sticks, maybe speck of dust in there or something. It sounds like RAM, the issue. Some stuff works normal, other stuff it's like it "forgets" you ever clicked anything. Only had that before with bad RAM, personally.
Try a system file check too maybe.
You have a software issue. Broken C++ redist or .net perhaps. Hard to say.
You have to understand that unless something gets changed on PC then nothing changes. So just think about it.
