pc and 360 wireless
8 Jun 2004
Reigate surrey
When i have my pc and Xbox 360 on at the same time,, the 360, disconnects itself from the net, saying it cant find the IP adress, is there something i have to do to enable multiple wireless connection??
Make sure that both the PC and Xbox are set to use DHCP for the IP as it might be you have set the IP manually on one or both and they are conflicting.
Aaah now thats the message i get,, sorry to be a nusiance,, but how do i go about that plz?
Need to know a few things first
What o/s are you running on your pc?
What network setup are you using? e.g. router ics....
ok XP home edition, version 2002, service pack 2, Binatone router, ENE CB-712/714/810, Cardbus controller,, any help??
Hi
To check that your PC is set to server assigned IP address follow these instructions
Click on Start
Goto Control Panel
Open Network Connections
Right click on Wireless Network Connection and select Properties
Highlight Internet Protocol (TCP/IP) and click on Properties button
Is the dot next to Obtain An IP Address Automatically ?
If it not then note down the settings that are on the screen before you think of making any changes incase the router is not set to use DHCP.
I do not have a 360 so not sure how to check on that
