Hi All,
I've moved my gaming PC which has a Creative Labs Xtreme Music card in it - all analogue outputs with no optical it seems. I have a 3.5mm cable going through to a L/R input on the amplifier - these seems to run Pro Logic. In games such as Dragon Age or TF2 you can hear some faint background sound on the rears but if you fire a grenade or start talking to somebody then turn around the voice cuts off instead of coming out of the rears. I've done a bit of reading on 5.1 PC gaming and it's still confusing me a little.
Would you recommend I upgrade to a better card with optical perhaps or can I purchase some extra cables and use the rest of the outputs into my amp ( it has a multi ch in section which I could use ).
Basically I would just like to have 5.1 audio like I do for my consoles which support it out of the box over optical.
Any help really appreciated.
