I have had a couple of threads concerning this but only for specific issues and under titles that may not directly point to the underlying project... i.e. building a PC based NAS.
I have started this thread to track the build and try to sort out any continuing issues with the help of the knowledgeable people here.
Ok so first off...
Aim
Current set-up on the NAS
Current Network Hardware
Current issues
Thanks
RB
Ok so first off...
Aim
- To have a 24*7 NAS capable of streaming to 4->6 HD (1080p) movies concurrently via shares (i.e. not as a media server transcoding the video).
 - Needs to be able to hold 2+ TB of data plus have a backup and be optimised for read speed over write speed.
 - Prefer it to be based on Linux (Redhat or CentOS as they seem more logical in their set-up to me over the Debian systems).
 - Prefer to stay away from 'application' images as I will probably use the server for a few other things like DHCP, DNS, NZBget, Transmission etc.
 - Needs to be able to play without stutter to both AC Ryan HD Mini and WD HD Live TV media players.
- Intel C2D 8500 (prob 8500 but certainly around that level).
 - MSI socket 775 (1*PCI-e x16, 2+ PCI slots, 4*DDR2, 6*SATA2). Will confirm model when home.
 - PCI-e low end ATI video card (using VGA connection, DVI available).
 - 5* WD Caviar Green 1.5TB drives (one RMA with WD now).
 - 300GB Samsung 7.2k HDD
 - 1TB Seagate Barracuda 7.2K drive
 - 250GB Hitachi drive
 - Dell Perc6 SATAII raid controller (8 drives, PCI-e X8). Awaiting cables delivery and motherboard with 2*PCI-e x16 or onboard video.
 - Midi tower case
 - Icydock 3->5 drive hot swap bay
 - 2*Intel 1000Pro network cards (PCI)
- Built minus the PERC6 and one WD CG 1.5TB drive (RMA).
- CentOS 5.5
 - SMB for shares
 - mdadm raid 5 array for all WD CG drives.
 - 300GB drive as boot
 - 250GB drive as upload
 - 1TB drive as private backup (photos, documents etc).
- Cat5e cables
 - HP Procurve 1810-24G 24 port switch
 - D-Link E3000 N+ dual band Gigabit switch (4 port).
- D-Link DNS-323 (NZBGet newsgroup reader).
 - Workstation (Intel Pro 1000 network card)
 - Laptop (wireless N)
 - 2*WD HD Live TV media players
 - AC Ryan HD Mini media player
	Current issues
- Network transfers still slower than expected (approx 50MB/s read and 60MB/s write to the NAS)
 - Media players all hang when watching movies (single stream). AC Ryan hangs sooner than the WD (8GB MKV - ACRyan=10 minutes, WD = 30 minutes before first hang). A single drive light is solid on from the remaining 4 disks in the array. The movie resumes and all 4 drives activity lights flash as normal after 2-3seconds. This happens repeatedly.
- Checked drive using WD drive health check software. This highlighted the issue with the drive that has now been RMA'd to WD. No error detected on the current drive with the solid activity light during hangs.
 - Changed Sata cable
 - Changed motherboard Sata socket for that drive.
- Not all WD CG drives are the same revision 3 are newer. The RMA'd drive is of an older revision, the drive with the solid activity light is of a newer revision.
 - The cable between the media player (ACRyan or WD HD as I swap them around when testing) is fairly old and is two cables joined with a coupler. The copy speads were taken from my workstation connected to the NAS directly via the Procurve 1810 and 1/2 metre new cables.
 - The media player is connected to the D-Link E3000 along with the D-Link DNS 323 which may be active pulling from the news servers but only to a max of 1MB/s.
- Remove the WD CG drives from the Icydock and connect them directly to the motherboard.
 - Just purchased an Intel DP45SG Extreme Series P45 ATX DDR3 1333 2xPCIe 2.0x16 3xPCI 1333MHz FSB LGA775 Desktop Board. Should arrive at the end of the week. 4GB DDR3 ram also ordered for it.
.Thanks
RB
.  If Fedora 14 will do for the mean time I will wait for the new motherboard before rebuilding the workstation.
.  I have read the previous set of firmware should work but I cannot find it on the LSI site or anywhere else.  The latest LSI firmware was on softopia and not their support site for their 1068e cards
