Hey all,
So here is what happened.
I was gaming last week and my PC decided to shut itself down mid game and refused to turn back on.
I quickly narrowed it down to the PSU as the light on the back of it no longer functioned.
To be sure, I replaced the CMOS battery, checked all the cables, tried a new power cord, looked for anything amiss - nothing.
I even tried the paperclip test (which I never knew existed) on the PSU and alas, no fans, no lights.
Case closed I thought, so I ordered a new PSU (1200w Corsair).
Upon arrival, before fitting the new unit, I gave it a test with just the mobo and cpu plugged in - and the PC sprung to life, lights turned on, fans spun.
Great I thought, lets get it fitted.
Everything in place, cables double checked, properly seated etc I flipped the switch and BANG - a bright flash coming from inside the open PC case along with the horrid smell of burnt electronics.
I quickly unplugged it.
I was on the PSU side when I turned it on so know the spark did not come from that (its a corsair 540 double compartment case so its completely shielded from the main mobo), and after some inspection and sniffing, I tracked the offending smell to one of my GPU'S, a 980 ti.
In hindsight, I can only guess when my PC shutdown the first time, the PSU and GPU must have both gone kaput - something I had not considered.
Now I have been itching for an upgrade for a while now so have ordered new parts anyway but I am left with a PSU I do not know whether to trust or not.
Rather than risk blowing up a whole new system, I have purchased a new one but the question remains - what to do with the other?
Is there any way of testing its safety without risking anymore components?
I seriously doubt the warranty would cover it - what would you do?
Over 15 years of PC building and this is the first (and hopefully last) time I will experience this!
Thanks in advance
TLDR: New PSU/ GPU blew up, is it still safe/what to do with it?
Thanks in advance
