I changed my bios to fix a mouse issue as it was making my boot time extended by 2 minutes.
Trying to apply this fix in bios I disabled USB support thinking it would boot instantly bypassing my USB mouse and load into windows. This worked fine but I expected my USB items to then be recognised but now they arent.
Now I boot into windows unable to access my bios f2 as my USB keyboard also isnt recognised in either the loading screen or windows!
My problem lies with my motherboard as it doesnt have ps/2 support its only USB. I have tried taking the jumper off which puts it in recovery according the manual but it fails to post (Monitor doesnt come on with my beep) I then took the battery out for 5 minutes and replaced it and got an error saying.
firmare detected cmos bat failures cmos checksum error and something about system time? It then goes into system recovery as I loaded into windows once but now its changed. I reset pc and no-longer get this error so I think its just a warning that cmos had been reset. What can I do? seem to be stuck in a crappy LOOP!
Meanwhile pc boots and the 3 lights come on my keyboard but dont go off! I have tried my other USB keyboard but no luck either! Both are steelseries 7G & Zboard. Stupid xai getting me into this in the first place.
