- 11 May 2014
Hi
I would like to build a PC purely for MS Flight Simulator X and wondered if the below specs will provide good performance. I would like to fly with good and complex addons. My budget is £1000
Antec 300 Three Hundred Ultimate Gaming Case - Black
Stage 1 Intel: Overclock of CPU - 4.2GHz Overclock - Haswell K Edition Processors Only
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail
Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler
Asus Z87-PLUS Intel Z87 (Socket 1150) DDR3 ATX Motherboard
TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLYD38G2133HC11ADC01)
Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card (GV-N770OC-2GD)
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
Corsair Builder Series CX 600W V2 '80 Plus Bronze' Power Supply (CP-9020048-UK)
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02733)
Asus USB-N10 Micro USB Network Adapter Wireless-N 150Mbps
System Build Fan - Noiseblocker BlackSilent Pro Fan PLPS - 120mm PWM [EXNO-001]
I would be really grateful if anyone can give me feedback on possible performance of FSX if I used the above? I'm not looking for 60fps, but as long as I can land at Heathrow with a good addon I.e. PMDG 737 etc, UK2000 Heathrow, REX etc at around 20FPS then I'm happy. I can't afford a super rig unfortunately.
Also should I keep with Windows 7 or go with 8.1?
Many thanks
Many thanks
Although others will swear by Windows 8.1. I wouldn't have thought there would be a huge difference in performance between the 2 operating systems
