Hi there,
I'm hoping to build a new system with gaming specifically in mind and wondering if anyone would mind helping me out/giving advice on the spec i should go for.
My budget is around £700, though i would go slightly over if necessary. I already have a decent screen, keyboard, mouse, etc so only need the box.
I've read a few reviews and forums trying to work out which components would best compliment eachother, and so far this is what i've come up with...
I am a bit 'amateur' when it comes to tech talk so please be easy on me
Anything at all, if i should change anything, can get a better deal etc is appreciated. Thanks in advance.
.Anything at all, if i should change anything, can get a better deal etc is appreciated. Thanks in advance.
). Would this be a much better system for the price? thanks again
, and if it will get old in 8months then you can swap it for something better
