PC build for £1600
9 Feb 2010
Hi there, I’ve decided its time to upgrade my aging PC, its been nearly 7 years since my last upgrade and I’ve spent many hours trying to catch up with the latest tech and im a little overwhelmed by what’s out there.
My budget is around the £1600 mark, I will be using the PC for mainly sound video recording/editing and also some gaming but im relaxed about the GFX card as I would prefer the spend more on the mobo and cpu. I currently have a dual monitor setup but im going to be changing this for a single 4k screen, id expect to have minimum 16GB ram
I have a large Antec tower case which should fit everything in with very good fans and cooling. The PC will be based on the intel i7 CPU (exact type I need advice on). I would also only need one SSD whether that’s standard SSD of M.2 whatever is fastest. I’m not to fused regarding over clocking so air cooling should suffice, Also a new modular PSU I expect to be around 800watts
Any recommendations on bundles would be greatly appreciated.
My previous build was purchased from overclockers and its done me very well over the past 6 years.;):)
