PC Build For Cinema 4d
27 Oct 2013
Sheffield
Hi,
Im building a PC for a friend to use Cinema 4d to model products. I have been budgeted with £500-£600. This is what I have come up with.
YOUR BASKET
1 x Intel Core i5-4590 3.30GHz (Haswell) Socket LGA1150 Processor - Retail £157.99
1 x Corsair Hydro H80i High Performance Liquid CPU Cooler (CW-9060008-WW) £79.99
1 x Asus Z97-P Intel Z97 (Socket 1150) DDR3 ATX Motherboard £70.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £66.98
1 x Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S3B7A/120G) **Upgrade Bundle Kit /w Adapter** £56.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01) £55.99
1 x EVGA 430W 80 Plus Power Supply (100-W1-0430-KR) £32.99
1 x BitFenix Neos ATX Tower Black/Red £29.99
1 x LG 24x DVD±RW SATA ReWriter (Black) - OEM GH24NSC0.AUAA10B £13.99
Total : £580.01 (includes shipping : £11.75).
Any pointers to something more suited would be great.
Edit: It has been requested to have hydro cooler and red styled case.
Dan
drop the Z97 board. If you are not overclocking then you won't need it. A H81 will do the job.
Also will need a cheap graphics card. Something along the lines of a GTX750 will do the job. Take the load off the cpu graphics.
Agree with above plus more ram 8gb is not enough need at least 16gb. Def Nvidia card GTX 750ti or above for CUDA support (think Cinema 4D uses it) and drop the H80i cooler. I wouldnt spend £80 on a cooler for a non k CPU as its not going to be overclocked. Look round the £20-£30 mark.
With the saving on the H80i try and see if you can fit a Haswell i7 in the budget as Cinema4d will benefit more from the Hyperthreading.
Remember I have only been budgeted upto £650 Theres no way I can stick an i7, 750ti and 16gb of RAM in with the budget I have been given. My friend has also asked my to take out the i5 4590 and go with a 4690k which I will overclock for him.
Cinema 4D really wants a Discrete graphics card.
They go as far as recommending an AMD or NVidia. Intel on board graphics are really not recommended:
http://www.maxon.net/?id=311
Cinema 4D itself doesn't use Cuda, although some 3rd party render engines (Octane, Thea etc) & plugins (Turbulance FD) do.
So AMD or NVidia is fine.
Doesn't have to be top end, 260X will be fine :
http://www.overclockers.co.uk/showproduct.php?prodid=GX-329-SP&groupid=701&catid=56&subcat=1866
You'll have to trim the CPU & cooler to fit it in.
Don't worry about RAM, you can easily add more later as your projects grow in ambition.
YOUR BASKET
1 x Intel Core i7-4771 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £239.99
1 x Asus GeForce GTX 750Ti 2048MB GDDR5 PCI-Express Graphics Card (90YV05J0-M0NA00) £109.99
1 x TeamGroup Elite Black 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD316G1600HC11DC01) £95.99
1 x Toshiba 2TB 7200RPM SATA 6GB/s 64MB Cache - OEM (DT01ACA200) HDD £61.99
1 x Gigabyte B85M-DS3H Intel B85 (Socket 1150) DDR3 Micro ATX Motherboard £53.99
1 x SuperFlower Golden Green HX 350W "80 Plus Gold" Power Supply - Black £36.95
1 x Raijintek Arcadia Mid Tower USB 3.0 Case - Black £24.95
Total : £633.44 (includes shipping : £8.00).
