PC Build for Xplane and MS Flight Sim 2020 Advice Needed
27 Sep 2004
Hi all,
Not posted here for well over 10 years but am looking to get back into Xplane flight sim and maybe MS Flight Sim 2020 and am in need of advice to either build my own tower or buy one pre built.
Budget wise am not sure yet maybe around £800 mark.
Chris
Dam can't do a basket and copy it from my phone
So basically
Ryzen 3600
Teamgroup 16gb 3200mhz ram
Phantecs 550w gold psu
Gigabyte1660 super
1tb nvme wd 550
Kolink citadel case
Msi MSI B450M PRO-VDH MAX
Arctic e34 sport cpu cooler
All comes yo £800.
Probably go with this for a FS20 build, just about make it do'able with £800.
32GB RAM in there as well, as the consensus seems FS20 will most definitely use it.
My basket at Overclockers UK:
Total: £803.89 (includes shipping: £0.00)
Thanks for the advice so far people. Am toying now with the idea of just building one for Xplane instead and not MSFS2020. Could I get a system a lot cheaper than £800 that would run Xplane
A lot cheaper? Sorta but at cost of lower performance mostly. The current build suggestion is just a solid bang for buck 1080p build...
You could shave £80 if wanna cheap out and get a Ryzen 3100 cpu, another £30 for a non modular psu, £40 less on a 16GB RAM kit, £40 less and get a 500GB SSD etc.
