Hello all, first time poster, lurker for a while.
I've decided to take the plunge and build my own PC. Mostly it will be used for general use to do with work, playing games, poker, general internet browsing etc etc.
Top end budget is £1100 for the actual rig as the other £900 will be used for the U3011. I will also be buying 20" dells to go alongside this in the near future as well so this will have to be taken into account with the graphics card.
Because I'm on my work PC i can't post the spec i currently have in the basket because i can't get the BB code (i will do this once home today).
I know the offers will change as of tomorrow, hopefully i will be able to get a solid spec that will be fairly future proofed but also with the ability to expand if needs arise. e.g. SLI
Can anyone spec me something around this and i can post my spec later to see where we can change things?
Sorry for the long post!
. Only thing to think about is tomorrow the weekly deals change, so you're ram/ssd/gpu could all go back up to full price, but other stuff may go down, luck of the draw really.
