PC Build, no budget.
23 Apr 2014
Hello,
I'm looking for to build a PC for my sister, she's looking for something which can handle mainly Sims along with her schoolwork etc..
The cheaper the better.
Thanks.
Can't do a full build suggestion but for the sims 3 and coursework would a apu and ssd be a better choice
Yes it would. I could play Sims 3 maxed out on a laptop with an HD4530M, so an APU would be more than sufficient.
I would do a spec but since I'm at work, I don't have the basket add-on, so I would have to link things untidily. Someone else will do one for you soon though I expect. :)
e; Okay sorry, I couldn't help myself...
AMD 6600K APU -
http://www.overclockers.co.uk/showproduct.php?prodid=CP-355-AM&groupid=701&catid=1967&subcat=1944
£71.99
Gigabyte F2A88XM-DS2 -
http://www.overclockers.co.uk/showproduct.php?prodid=MB-474-GI&groupid=701&catid=1903&subcat=2399
£38.99
TeamGroup Xtreem LV 8GB 2400MHz -
http://www.overclockers.co.uk/showproduct.php?prodid=MY-032-TG&groupid=701&catid=8&subcat=1387
59.99 (£67.99 when offer expires)
Crucial M500 120GB -
http://www.overclockers.co.uk/showproduct.php?prodid=HD-027-CR&groupid=701&catid=2104&subcat=1427
£54.98
Silverstone Strider SFX 300W -
http://www.overclockers.co.uk/showproduct.php?prodid=CA-355-SV
£37.99
Aerocool QS-102 -
http://www.overclockers.co.uk/showproduct.php?prodid=CA-113-AE
£22.99
TOTAL - £296.53 (incl. £49.42 VAT & £8.00 P&P)
