Hi, my motherboard finally gave up after 6 years of service (AW9D-Max). So I am getting a bit of an upgrade and was hoping one or some of you knowledgeable types could let me know if I am choosing anything stupid.
I already have a power supply, an OCZ 600W modXstream (OCZ600MXSP) which I think should hold up fine. Of course I have a good large case as well, monitor, hard drives, optical drives etc.
However since my motherboard is so old there really is no point going for a direct replacement, it is probably time my first gen Q6600 bite the dust too. Anyway to get to the point this is what I am thinking of buying:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-418-IN
http://www.overclockers.co.uk/showproduct.php?prodid=MB-391-GI
http://www.overclockers.co.uk/showproduct.php?prodid=MY-114-GL
http://www.overclockers.co.uk/showproduct.php?prodid=GX-052-HS /or/ http://www.overclockers.co.uk/showproduct.php?prodid=GX-049-HS
I am pretty sure they are all compatible but I am pretty rusty of my PC hardware. Also if anyone can suggest any better alternatives I would be appreciative of your opinions!
