- 18 Aug 2012
Ok i have put together 2 specs for a budget gaming PC that will play games such as Battlefield3 with a decent fps.
I would be very grateful if someone could give me their opinion on which would perform the best for the purpose and if i should change something to make it compatible.
Which processor+Mobo?
Intel i5 2500k
ASUS P8H61
OR
AMD FX 4170
ASUS M5A78L
Which GPU?
Sapphire ATI Radeon HD 7770
OR
Zotac GeForce Nvidia GTX 550 Ti
These are the parts that want to use for the RAM ect..
Corsair Vengeance 8GB RAM (2x4GB)
WD Caviar Blue 500GB HARD Drive
XFX Core Edition PRO 650watts PSU
Coll Master Elite 430
If you could give me some advice on the processor/motherboard and the Graphics cards that would be great and also any advice on the other parts would be great too.
Budget is £450-£600 so bear that in mind with your suggestions and i will look forward to hearing them.
Thx in advance
Alex
Intel i5 2500k
ASUS P8H61
OR
AMD FX 4170
ASUS M5A78L
Which GPU?
OR
Thx in advance
Alex
