Hi all,
So far I have the following PC at £1080, but need to get it under £700. Of course I expect performance to drop but I think this build is overspecced anyway.
The goal is - to be able to play Factorio, Satisfactory and other similar titles. This spec far exceeds that. What would you change to get it under £700 while ensuring it can last a couple generations of upgrades?
MSI Mag Tomahawk B550M Mobo + Ryzen 5600X CPU = £390
3060 Ti Founders Edition GPU = £380
MSI Mag Force Case = £48
16GB 3600Mhz CL16 RAM = £82
CPU Cooler = £30
PSU = £75
1TB NVMe Storage SSD = £75
Also, let's assume we can get a GPU at MSRP. Thanks in advance
Edit: I'll keep tweaking this list below for the final spec based on comments in the thread:
Mobo: MSI B450 TOMAHAWK MAX II AMD - £60
CPU: **B GRADE** RYZEN 5 3600 - £140
CPU cooler: Arctic Freezer 7 X Air Tower CPU Cooler - £17
GPU: 3060 Ti FE - £300
RAM: VULCAN Z T-FORCE 16GB (2X8GB) DDR4 PC4-25600C16 3200MHZ DUAL CHANNEL - £70
Storage: ADATA SU630 480GB 2.5" SSD - £38
Case: **B GRADE** Kolink Nimbus RGB Mid Tower - £28
PSU: Corsair CV550 - £40
Total = £693
CPU Cooler = £30
PSU = £75
Total = £693
