PC Build
3 Mar 2006
Hello im new to the forum and in the process of selecting components for a new quiet build. My budget is around the £700 mark and the PC needs to be a general all-rounder. What I have so far is as follows:
Case/PSU
Antec P150 Quiet PC Case - 430w HE Modular PSU (CA-047-AN)
Motherboard / RAM / Processor
GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit CAS2.5 (GE1GB3200BHDC) (MY-005-GL)
Asus A8N-SLi Premium nForce4 SLi (Socket 939) PCI-Express Motherboard (MB-111-AS)
AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - Retail (ADA3700BNBOX) (CP-121-AM)
Graphics Card
PowerColor ATI Radeon X800 GTO 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-054-PC)
DVD/CD-ROM/RW
Sony DDU-1615 DVD-ROM (Silver) - OEM (CD-015-SO)
AOpen DUW1616 Chameleon 16x DVD±RW Dual Layer ReWriter inc. Ivory/Black/Silver Bezels - Retail (CD-008-AO)
HDD
Western Digital Caviar Special Edition 160GB 1600JS SATA-II 8MB Cache - OEM (HD-047-WD)
Opinions, comments and recommendations would be appreciated.
If your not worried about overclocking, the new batch of opterons are looking good. Pick up one of those instead of the 3700+ and you'll save 40 odd quid.
Thanks for the reply. Im not worried about overclocking to be honest although the CPU, mobo and memory I have listed above are a bundle deal so im probably saving about 40quid as it is anyway. I'll check it out though for sure.
the bundle saves you.. £0... Go for a Asus Crossfire MVP board with the same RAM and CPU and you'll save about £40 - then put the saving into an X850XT Graphics card. Other than that nice spec :).
AMD Athlon 64 3700 Retail / Asus A8N-SLi Premium / 1GB GeIL CAS 2.5 PC3200 Dual Channel Kit - Bundle (BU-029-OK)
Price: £284.85 (£334.70 Including VAT at 17.5%)
MY-005-GL GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit CAS2.5 (GE1GB3200BHDC) (MY-005-GL)
£49.95 £49.95
MB-111-AS Asus A8N-SLi Premium nForce4 SLi (Socket 939) PCI-Express Motherboard (MB-111-AS)
£104.95 £104.95
CP-121-AM AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - Retail (ADA3700BNBOX) (CP-121-AM)
£129.95 £129.95
Subtotal £284.85
