- 10 Jul 2009
Basically went around the local high street shops and got offered a ton of crap for a lot of dosh.
Not being a fan of shopping online due to mates being ripped off or having to return parts and the extra hassle. Went to local shop and the dude shops off ooc and said he'd build me a rig and would be ready by tuesday 14th July. Feel comfy with this as if it breaks , he's just 1 mile down the road.
SPECS
AMD Phenom II X3 720 black edition AM3 2.ghz
ASUS M3N72-D - motherboard - ATX - nForce 750a SLI
Akasa power unit (not sure if it was a 650W or 1000W one now
22 inch widescreen monitor 1680x 1050 (Yusmart JT 229RP black)
Samsung 1TB SATA2 Hard drive
Corsair Twin2X 4GB DDR2 (went cheapo here as I'll get up to 8Gb DDR3 later)
Dual layer DVD Rewriter drive
Coolermaster ELite case
MS Vista 64bit premium with IE7 voucher
GeForce GTS 250 1024MB GDDR3 PCI-Express Graphics Card (can add another one much later)
Price including VAT and labour comes to exactly £750.
Going to get another monitor later so I can multitask.
The rig is basically for Eve - Online, L4D and possibly a little crysis. I know it will play eve easily , my issue is when you get into those fleet fights and your system just starts raging at you.
Helpful reviews or opinions would be appreciated in simple English as I am not a native speaker or techie.
SPECS
