Hey guys I'm planning on building a PC just after Christmas with whatever money i have at the time to spend (I'm 15 and aiming for around £1200 maximum). I've been planning it for ages and i make a new build design every month or so. If any of you could recommend any changes etc. that would be greatly appreciated. I plan to use this for video editing, gaming, everyday activities and possibly live streaming HD video if i buy a capture card.
Intel Core i7 2600k @3.4Ghz (might OC) (or AMD 1100T route??)
http://www.******.com/product/252535
GTX 560 (or Ti ??) 1GB
http://www.******.com/product/267865
Corsair Vengeance 12GB (or 8GB ??)
http://www.******.com/product/248756
Arctic Cooling Freezer 7 Pro
http://www.******.com/product/176157
LG 22x Optical drive
http://www.******.com/product/263923
Asus P6X58D-E Motherboard (Really not sure)
http://www.******.com/product/219007
NZXT Phantom (White or black ??)
http://www.******.com/product/240815
Samsung Spinpoint F3 1TB x2 (RAID 0 or not?? *I can't afford backup as well*)
http://www.******.com/product/173804
Corsair Force 3 120GB SSD
http://www.******.com/product/268693
Antec TruePower 650W Modular PSU
http://www.******.com/product/159920
This is my first PC build but I have done a lot of research into learning what I need etc. Basically, as I'm only 15 and don't have a job yet, I probably won't upgrade for quite a while so I want the best parts possible for my budget.
Thanks a lot,
Max
P.S. I will also need a monitor, keyboard, mouse and possibly speakers included in the budget, with hopefully a little room for powerline adaptors and other things
Thanks a lot,
Max
