Pc Build
31 May 2012
I was wondering if anyone could help me with a computer build, i have had it at around £800 but looking for something a bit cheaper, i do game but will not be using it for serious gaming mainly i will be using it for Diablo 3 the parts i do want though is;
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W)
Gigabyte Z77X-UD5H Intel Z77 (Socket 1155) DDR3 Motherboard
for now the rest I'm not to fussed on as upgrading is always an option, i will also need windows as well if anyone could take the time to help it would be really appreciated.
Thank you for your time reading my post.
you say you have 800 pounds? then i've got a list for you, the motherboard and cpu seem fine good choice they come to 319.93 if you then take these:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-ZA&groupid=701&catid=7&subcat=736 for the case
http://www.overclockers.co.uk/showproduct.php?prodid=MY-094-KS ram
http://www.overclockers.co.uk/showproduct.php?prodid=GX-123-MS&groupid=701&catid=56&subcat=1752 graphics card
http://www.overclockers.co.uk/showproduct.php?prodid=CA-048-CS&groupid=701&catid=123&subcat= psu
that comes to 665.89 without hard drives and that leaves you some spare if you wished to upgrade any of the items just throwing ideas about but i have most of those parts and they work an absolute treat
Nice choices, a lot better than what i picked ! well yeah i would spend around £800 but I'm getting them in stages that bulk of money isn't available for me at the moment with the bills i have etc so i was just planning on getting a new part every pay day ( bad idea or? ) give me a project to do, it will also be my first build but i have experienced friends who can help.
I like the selections and the price of that ! ill have to buy windows also
Thank you very much for your time and advise i appreciate it thank you.
haha no problem, yes windows i'll find you a price for that and do you need hard drives? but that is what i have just ordered and it is amazing except i went for a better processpr the i7 3770k and a slightly cheaper motherboard well worth it trust me and yeah buying a part every pay day sounds good i mean bils have to be paid hope your pleased when you finally get it finished
Yeah i will need hard drives so with windows and hard drives im looking at that price being around £750 mark, lets hope waiting to buy the parts do me favours might get cheaper !
thank you again
heres a link for windows http://www.overclockers.co.uk/showproduct.php?prodid=SW-127-MS&groupid=33&catid=1555&subcat= its an oem license so it needs to be bought with a hard drive and be used in a system your building which you are so heres a hard drive to go with that http://www.overclockers.co.uk/showproduct.php?prodid=HD-379-WD&groupid=701&catid=14&subcat= together that is 820.86 eehh just a tiny tiny bit over lol if you wished you could go for a 500gb hdd for 20-30 pounds cheaper if you wished
