pc build
28 Jul 2012
Lancaster
hi guys just looking to build a new pc and want some advice.so im looking to build one for about £600.the first build ive been looking at.
i5 4670k haswell-£160
asrock z87 extreme 4-£90
hd 7850-£115
850w power supply for about £100 to £150 but don't know which one to go for so if someone could rec1 to me.
8gb vengeance ram-£60
don't no a case yet or hardrive.
Been looking at some reviews on the net a lot of mixed reviews about going for the haswell.
The second build.
i5 3570k-£160
asrock z77 extreme 6-£100
and all the other stuff same as the first build.
so some advice would be much appreciated and thanx for your time in advance.
AMD Build
YOUR BASKET
1 x Sapphire Radeon R9 270X Boost OC 2048MB GDDR5 PCI-Express Card £149.99
1 x AMD Piledriver FX-6 Six Core 6300 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £89.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £79.99
1 x Asus M5A97 EVO R2.0 AMD 970 (Socket AM3+) DDR3 Motherboard £74.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x SuperFlower Amazon 550W "80 Plus Bronze" Power Supply £49.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x NZXT Source 210 Elite Midi Tower Case - Black £39.95
1 x Raijintek Themis Direct Contact CPU Cooler £17.99
Total : £617.87 (includes shipping : £12.50).
_________
Intel Build
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £161.99
1 x MSI Z87-G55 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £91.99
Total : £626.88 (includes shipping : £12.50).
_____
As you can see the intel build lacks an SSD, however one can easily be added at a later date :)
so you rec go for the haswell build instead of the ivy bridge build its just that ive heard the haswell gain to much heat.
thanx for the help m8.
Yeah no reason to go ivy over Haswell. As for the i5 v the fx6300 option above....both are good value for the money.
Yep, Haswell over IB everytime, the heat only comes if you start running lots of volts through it, and it's not like Piledriver is a fridge. :P
I'd personally go for the Intel build over the AMD one, simply for the upgrade path later on and at this level it seems silly not to :)
