PC build
The motherboard seems to come with a free Corsair H75 cooler - so there's no need for that big air cooler.
Some red RAM would surely be in order, too?
That case is designed for big multi-GPU watercooling builds. You could certainly save a bit on that.
could you recommend some ram then? i have some olde vengeance ram atm, but im looking for some decent low profile ram (16gb). and i shall take off that air cooler as well in that case.
Also does anyone know if there are any decent Wi Fi cards about?
Right just heard from my work i might be moving around a lot, ontop of this i will need a Gaming machine which i will be able to carry around with ease. Anyone got any ideas? Pre-made/self build doesn't matter to me.
This will be used for gaming and some light Building design programmes. The cheapest will be the best, also providing it will run a decent temp.
just about to post about the case too.
