PC build
28 Oct 2014
I am thinking of getting all of these components:
GIGABYTE GeForce GTX 770 WINDFORCE 3X OC 2GB GDDR5
NZXT Phantom 410 Case - White - No PSU
GIGABYTE GA-Z97X-SLI Intel Z97 (Socket 1150) Motherboard
Samsung 224DB 24x DVD Re-Writer - SATA - Black - OEM
Corsair Builder Series CX600 - 600 Watt 80 PLUS® Power Supply
Crucial Ballistix Tactical 8GB (2x4GB) DDR3 PC3-14900 1866MHz Dual Channel Kit
4th Generation Intel® Core™ i5 4690K 3.50GHz Socket LGA1150
Seagate Barracuda 1TB 64MB Cache Hard Drive SATA 6GB/s 8.5ms 7200rpm - OEM
And I am not sure if the motherboard is fine with these components
And also I dont know which cooler to get and do I need one for a graphic card and the cpu or just for the cpu
ty
What's your budget?
I've put something together that is along the same lines as what you've suggested with a few key changes:
PSU - No need to go more than 550w with a single card plus Superflower are a premium manufacturer
GPU - Comes with its own cooler and for a few pounds more you can get a gtx 780.
HDD - I've added a solid state drive as they really do make a big difference. Get one if you can afford it.
The other changes are purely personal preferences based on experience.
YOUR BASKET
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£14 Saving** £258.58
1 x KFA2 GeForce GTX 780 3072MB PCI-Express Graphics Card - Retail (78XNH5DN9IST) £215.99
1 x NZXT Phantom 410 Enthusiast Midi Tower Case - White/Purple £84.95
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
1 x Kingston HyperX 8GB (2x4GB) PC3-17100C11 2133MHz Dual Channel Kit - Black/Red (HX21C11BRK2/8-OC) £67.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £53.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £39.95
1 x Raijintek Aidos Direct Contact CPU Cooler - Black £14.99
1 x Pioneer 24x Internal DVR-221LBK DVD Rewriter - OEM £13.49
Total : £846.41 (includes shipping : £13.75).
