LIAN LI PC-C50B SD Card Reader Not Working
Hi,
I've had my LIAN LI PC-C50 B case for a few months now and have treid everything i can think of to try and get the SD card reader working but to no avail.
I've got an ASUS P8P67-M PRO motherboard, and the cable from the card reader is plugged into one of the USB headers on the baord. The light is on, but inserting a card does nothing and I can't find the card reader in device manager (Windows 7). I've tried plugging it into a couple of different headers, but others either produce the same result or not even the light is on.
I've also tried updating drivers for everything in device manager incase it was something labelled generically.
Any help would be much appreciated.
Regards,
RObin
Hi,
Regards,
RObin
. Does the PC detect it if you plug in a USB device? May want to check the in the BIOS, to see if there is anything to do with the USB headers and type supported etc.
