PC Case Advise
19 Feb 2020
Hi guys,
Can you advise me which PC case should I buy, please. I look to get:
  • Corsair 500D Obsidian RGB
  • Corsair Crystal Series 680X RGB
  • Cooler Master MasterCase H500M ARGB
I look to spend not more than £250.
Thank you in advance.
You can install 2 PC's in the P600s for starters, also check Gamers Nexus on youtube for case reviews. Airflow is important to keep your PC hardware cool during gaming.
I have the H500M and it is a great case. If water cooling and you fit a radiator immediately behind the 2x200mm front fans, then those fans become useless. I have had to replace them because of the noise they generated and lack of cooling benefit for the radiator. See this link https://forums.overclockers.co.uk/threads/add-a-2nd-radiator-in-custom-loop.18875191/ and https://forums.overclockers.co.uk/t...wanting-same-airflow-and-less-noise.18880940/ It would be good if the case could be sold without any fans and the price reduced as I have replaced all original fans for ARGB options.
Hi guys,
Many Thanks for your all replies.
I found a new H500M for £163 , I believe it's a reasonable price for this case...?
I just came across Phanteks Evolv X. Any ideas, please?
