PC case and 8800 gts
10 Jan 2007
Hi all, Im buying a new pc case but done have the biggest budget in the world but i really like the look of this case
Atrix 9006-B34 Silver Case
All i need to know is if my 8800 gts will be able to fit into this case before i buy it. Thanks in advance for the info
I'd imagine that the site you've linked to is a competitor so i'd remove it before a don sees!
Just post a pic of the case instead! :)
I see no reason why the GTS won't fit as it looks like a large case. The GTS is generally shorter than an atx motherboard is wide so you should be fine. Only the GTX is so long that you'd need to worry!
I'll see if i can get some interior shots of it.
gt
Edit: No such luck. But i should think it would fit.
Finally, a suggestion, it would be better (if you want a quieter pc) to get a case with 120mm fans rather than 2x 80mm fans at the front and a 92mm at the rear. The 120's will flow more air and do it quieter.
Something like a Lian Li PC7 or Akasa Eclipse would be a far better choice and will definately accommodate a GTS.
Lian Li PC7
Akasa Eclipse
If you're after aesthetics i find Lian Li to make beautiful cases. Plus the PC7 is a little more compact than the Eclipse so won't dominate your desk in the same way. Plus, it's a bit cheaper! ;)
Happy shopping! :)
