My requirments are quite simple, yet I am struggling to find a single case that suits my needs...
I need 4 external drive bays, for the insertion of a dvd drive, and a 4 drive hotswap drive caddy... I dont want or need any 3.5 bays/floppy drives whatsoever.
I would like it to be micro atx primarily, but as Im struggling to find a micro-atx only case that has more than 2 visible bays, a standard atx will do! But definatley less than 40cm high.
It seems to be the combination of 4 drive bays and 30-40cm tall that I am having the problem with... I really dont need any more bays than that!!
12cm rear cooling option.
My aim is to build a dedicated storage array/nas/web/print/gateway linux server, so I need it be small enough so I can hide it somewhere, yet house athe drive bays I require...
Most cases I have seen have needless floppy drive bays, or not enough visible bays.. or are simply too tall...
Im sure I will have to give a little on something!!
ANyone got any ideas/suggestions... as I cant seem to find the perfect solution, which probably doesnt even exist!!...
Thanks
Thanks
