- 22 Sep 2018
Hello!
I would like to ask you for a recommendation on the purchase of a computer case.
I will use an ATX size motherboard in the machine.
The processor will be an Amd 7800X3D, which I will use with either an Artic Liquid Freezer II 360mm or an EKWB EK-Nucleus AIO CR360.
The power supply will be a Corsair HX1000i.
Last but not least, the video card will be an ASUS TUF Gaming Radeon™ RX 7900 XTX OC Edition 24GB GDDR6.
I would like to place the cooling fin on the top of the computer case, because I know that it is the most efficient and therefore the most ideal.
The money I could spend on it: ~ EUR 200 (£170, USD 218)
What I want is glass on the sides of the machine housing.
It is important to be as quiet as possible with good cooling performance.
I also like traditional houses and dual chamber houses.
What do you think would be the right choice for me? Even offering more.
Thanks!
Thanks!
