Pc case window is broke
what make of case is it ? manufacturer may do spares if not better off removing it and buying a piece of clear acrylic got some off eBay once requires a bit of diy but not to difficult
nzxt tempest crafted series.
I will buy piece of clear acrylic but than how to mount it to side panel?
is it held on by clips/ plastic screws ? what i did with mine was remove damaged panel lay that on top of the new acrylic tape them together (masking tape will do) to stop them slipping around then use the holes as a template and drill carefully.. mine turned out well and gets rid of the fan grill too :)
