pc comunication
9 May 2007
hi. i'm currently in my second year of uni studying electrical and electronic engineering, for this semester i will have to build a devices capable taking orders from the pc. now i have almost no clue how this works, because i am going to program a micro controller to control the input and out put modules on the device and communicate to the computer, i will need to know exactly what happens.
in college i got 2 computers to communicate to each other, this was done using a dos application and was told that the process involved a handshake which the computer checks the hardware is connected.
1) is this still the same with windows xp sp3?
2) also is there a set pattern which i have to output / input ? ie send Hex F3 and if receive Hex 51 it means it connected properly?
3) what happens after the handshake?
4) using a parallel port to connect, can i change the pins to out / in when i like? or after setting a pin to input it must only input?
5)what voltage does the parallel port use as logic 1?
6)now i know i need to sync the device and computer data transfer speeds or the data coming in will be all wrong. how do i do this?
7) anything else i should know?
sorry for all the questions, this is probably the wrong place to ask anyway. but i don't really know any electronic forums.
bledd is saying that "didnt take no lectures" is a double negative, you're saying that you didnt take 'no lectures' , so you took some
Surely this kind of thing will be covered in your course. We're only just at the start of the second semester so Im sure it will all be made clear.
