PC & Console - Steering Wheel Setups
21 May 2018
South Wales
Not sure if this is the correct forum for this but I'm in the market for a decent steering wheel to use between my PlayStation 5 and PC for GT7, F1 23, AC, DiRT etc.
I have a budget of around £450 to spend... any recommendations?
I've not tried but PS4 are supposed to be compatible with ps5
I am debating the Thrustmaster TS-PC Racer Ferrari 488 Challenge Edition however, no pedals are included. The T3PA Pedals work as part of the eco-system, tempted! Probably settle on the complete T300RS GT Edition.
Not sure it works with ps5 either.
I went T150 to t300 to an osw direct drive and if I could do it again I would jump straight to the direct drive it's so much better.
My advice is to spend more now on a direct drive wheel like the fanatec 5nm/8nm models if you need ps5 compatibility. Or the moza bundle of your sticking with PC. If you get into the hobby you will only lust after a direct drive wheel anyway so spend more now to save money later.
PS5 compatibility is a must and DD isn't cheap either. The T300RS is faily priced, plugs, plays and complete.
What's the total cost of a Fanatec setup, servo, wheel and pedals?
I have Huesinveld sprints for pedals but i only play pc nowadays, son in law has a fanatec DD wheels and BJ pedals and the difference between rs300gt setup and his for myself was the pedals, hence the sprints :)
Fanatec setup is 700-800 I believe, it's a shame moza and assetek don't have ps functionality
Not sure I can justify that amount unless I forgo the PS5 and stick with PC for better options? Not heard of Moza or Assetek, good options?
That's a lot more than I was expecting to pay. Would I be able to expand on that in the future?
I've been looking at this:
Has anyone ordered from Fanatec as I'm interested in the CSL DD MCLAREN BUNDLE however, I'm unsure about the taxes, import fees etc?
