Pc constantly bluescreening
2 Dec 2006
Hello there, my pc has become incredibly unstable. Ive been running it at 2ghz for over a week now and it is still incredibly unstable. Upping the MCH, ram voltages, cpu voltages does not appear to fix it either though i beleive after upping the MCH voltage by 0.2 it did become a lil bit more stable but cant really prove this.
Im thinking its my motherboard as even from when i first got the pc it was messing about with me when overclocking and has gradualy got worse.I never sent it back stupidly and i bittlery regret it.
My pc randomly blue screens when only on msn etc and also in games. It appears to be more frequent when gamign but sometimes will do hours without a bluescreen. Further more my pc seems considerbly less stable at night. For some odd reason going on cam especialy seems to trigger off mass BSOD's which can come every 5minutes. But also sometimes when not on cam and of a night especialy i will have pc crashign every 10min.
So whats the connection, stress testing it doesn't seem like it would prove much when it will spontaniously crash anyway and therefore i cannot prove it was the stress test that caused it.
Only recently i had to replace my GPU and it was stable for the first few days and passed 3dmark etc at maxed out settings all fine. A few days later it started bluescreening randomly untill now i cant really do much on my pc. I think today it has blue screend at least 2/3 times in the last 5 hours, odly none of theese occured when i did about an hour total of gaming. I would estimate that after about 9ish my pc will start bluescreening every hour and possily after about 11 tonight it will blue screen 2-6 times every hour depending on how much of a **** it wants to be. Now this would suggest it is related to tempreatures but ive checked them and its all fine so really doesn't make any sence.
Also because my motherboard is ABIT can i even get a replacement any more if this is what is causing it?
Thanks.
Whats the error message youre getting with the BSOD? turn off automatic restart so you have eough time to note doen the message, cant really do more til know the error code
Mm ok you want the whole lot or just the bit at the top which is something "less or no equal" somethign like that. Also how do i turn off this automatic restart?
If its IRQL less than or not equal to then its a RAM issue, try manually setting your freq and voltage in BIOS, if that doesnt fix it then try with just one stick at a time, maybe one of your sticks died
Ah cheers, always thought that was a CPU issue. Alaso another problem with my motherboard, i cant get 4-4-4-12 doesn't physicaly let me choose it. Dont know why. So im guesing this is either a mobo issue to do with my ram slots or just ram issue. Hopefuly just ram. Ill check it out in a bit just after i finnished ma work.
Though having said that all my ram settinsg but voltage are set to auto so im guesing its more likely one stick is dead but surely then it would just never work instead of crashign hourly?
I did a lil look around and sposidly its caused by drivers trying to access an incorrect memory adress. Mm this could have been caused when i got my new graphics card and havn't properly uninstalled old drivers perhaps?
Although even before my new gpu i still had random screw ups wid this pc. It just hates me so bad. lol.
Serposidly according to vista i need to update my network drivers. I find this a little odd tbh but being abit it appeasr they no longer host the drivers and i have no idea where else to get them as google shows no results :/
:EDIT:
looking on realtek website i dont get it. I have to choose between PCi-E and PCI after following the links to get to what i think would be my driver for my board. Is this asking me which slot my network card goes into because obv its motherboard network and therefore neither or what kinda board i have. Sigh :S
ooo gd idea cheers. Though windows own link to where i was ment to download the drivesr from didn;'t work. Worth a shot though i gues.
:EDIT:
hah just crashed downloadign it, that cant be healthy
