- 23 Oct 2013
hi, I'm having a problem with my pc crashing (just turning off and hard resetting, no blue screen, no errors, just a sudden cut back to bios). I've not had any problems for years and suddenly last week when a group of us started to play Ark together, boom, reset after about 30mins. I've "played" about 4 hours of Ark and it's hard-reset about 5-6 times. I've not had a problem with anything else, so I put it down to Ark...
so, I tried removing my OC and using stock speeds/voltages and a clean install of my Nvidia drivers (with the latest 353.38) and windows update. still crashing in Ark.
so, I thought I'd give Evolve a go, with it now being f2p.
2mins into the tutorial and boom, back to bios...
So, I then did:
memtest (clear for an hour)
prime95 (clear for an hour)
^so, I think/hope this rules out cpu and memory
I even updated my bios
re-installed a load of drivers
pc works fine in Rust, Overwatch, Diablo, but not Ark or Evolve. But, I admit they're more gpu heavy. I know I've had driver problems for years with my out of date X-Fi soundcard, so to rule that out I tried FurMark and boom, crash... (so I'm guess that something with no sound rules out the soundcard?!?)
I've been trying to monitor temps and I don't think it's that, as nothing gets over about 72°C
Any advice where to look, or what to try next? (and how?)
I'm now wondering if my "bronze" level psu is starting to show its age and is worth changing to a "gold" rated one. But, apart from that, I can only think it's the GPU, which I got from Overclockers (order date 20 Jun 2015), so at least it's in warranty, i think...
spec:
i5 2500k (was oc'd to 4.3, but now back to stock) with 212 Evo cooler
Zotac GeForce GTX 980Ti AMP Edition
Cooler Master G750M 750W bronze psu
Soundblaster X-Fi Music
Gigabyte z68xp-ud3 motherboard
8gb Corsair Vengeance cml8gx3m2a1600c9
Win7 64bit
So, does it sound like PSU or GPU is the likely culprit? any idea how I can test (don't have either spare)?
cheers for any help
So, I then did:
spec:
Win7 64bit
cheers for any help
