- 17 May 2015
Ive had this problem for aslong as i can remember, built this pc coming up to 3 years now and this crash is now testing my resistance to being thrown out of the window.
Specs - most of my stuff has been bought from overclockers.
Gigabyte Z77-D3H
Intel core i5 3570k ivybridge (overclocked from overclockers to 4.4)
GTX 580
850w PSU
2x4gb Vulcan ram
1tb harddrive
The ram above is new as i found a couple of errors with my old ram from the last test of v6 memtest so replaced that and hoped it would solve it but no
What ive done.
Cleaned inside
Antivirus scans etc
Used Seagate to check harddrive
memtest then replaced ram
Updated bios/via audio driver via @BIOS and audio from the cd the motherboard came with
cried.
Kept an eye on temperatures but seems fine to me
What possible solutions im thinking of.
disabling some sort of audio in bios.
Crash usually occurs when playing games/downloading which is usually what i do anyway. The crash seems completely random i could play for days/weeks and it be fine then all of a sudden i crash 3 times in one night which isnt cool when its usually at the end of a setup/heist on gta 5 XD The buzzing sound doesnt always happen and i cannot do anything when it crashes apart from holding power button down.
Any help would be greatly appreciated and if you need to know any more info please ask
EDIT: also thinking a format may help because takes a while to shut down and load sometimes so maybe some windows bug or something 414gb/931gb on harddrive
EDIT x2: Format didnt help
EDIT x3: Still crashing with new graphics card (GTX 970)
Gigabyte Z77-D3H
GTX 580
850w PSU
2x4gb Vulcan ram
1tb harddrive
What ive done.
Cleaned inside
Antivirus scans etc
cried.
