PC Crash
29 May 2009
Heey Ladies and Gentleman,
I occur many times an error that my pc freezes, when my pc freezes it makes a weird noise trough my headset (and when my headset is popped-out) it goes trough my speakerset.
Then I have to reset my system, to get the PC to work.
The following information I get from system log:
The driver \Driver\WUDFRd failed to load for the device Root\SIDESHOW\0000.
Log Name: System
Source: Microsoft-Windows-Kernel-PnP
Date: 1-4-2010 19:26:00
Event ID: 219
Task Category: (212)
Level: Warning
Keywords:
User: SYSTEM
Computer: Nemean-PC
Description:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9C205A39-1250-487D-ABD7-E831C6290539}" />
<EventID>219</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>212</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2010-04-01T17:26:00.674400000Z" />
<EventRecordID>3616</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="56" />
<Channel>System</Channel>
<Computer>Nemean-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="DriverNameLength">18</Data>
<Data Name="DriverName">Root\SIDESHOW\0000</Data>
<Data Name="Status">3221226341</Data>
<Data Name="FailureNameLength">14</Data>
<Data Name="FailureName">\Driver\WUDFRd</Data>
<Data Name="Version">0</Data>
</EventData>
</Event>
And:
The UMDF reflector was unable to complete startup because the WUDFPf service was not found. This service may be started later during boot, at which point Windows will attempt to start the device again.
Also I see information about the Kernell-Processor-Power.
Then I see:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 1-4-2010 19:26:01
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Nemean-PC
Description:
Event Xml:
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2010-04-01T17:26:01.704000000Z" />
<EventRecordID>3623</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
Hope you guys have any idea about this weird problem.
System Specs:
Intel Core 2 Quad Q9450 @ 3.2 Ghz.
XFX nForce 780i 3-Way SLI Intel
Corsair Twin2X 4GB DDR2-800 CL5 EPP DHX kit
And a Scythe Mugen 2.
Is your overclock rock solid? I used to get all sorts of errors when the system crashed. What are you doing when this happens?
I have stresstested it for 24 hours, + an intel burn test, and the system was stable.
And I am only running XFire + MSN.. with firefox.. but when I start watching an online video. My system freezes.. ><
