Hi
My PC has started crashing whilst playing Halflife 2 episode 1.
it played halflife 2 fine back when that came out.
it did used to have the odd funny moment with doom 3 a little while ago too.
my spec:
AMD Athlon 64 3000
Asus K8V-X mobo
2x512mb OCZ Ram (the ones with gold heat sinks)
Thermaltake Purepower 480W PSU
Ati 9800 Pro (i think its the saphire one)
PC IS NOT OVERCLOCKED
one 80mm case fan at the front
one 90mm ish fan at the back
currently have the side off the case aswell.
the game plays for about 30mins or so, then the PC crashes, and usually restarts, although sometimes it doesnt.
a few weeks back i was running some graphical demos and it crashed a couple of times then too.
Any suggestions?
is there any diagnostics software i can run to help me find whats wrong?
Thanks guys
Pete
my spec:
AMD Athlon 64 3000
Asus K8V-X mobo
Any suggestions?
Thanks guys
Pete
