- 1 Jun 2012
- UK
Hi, been having an odd issue with my PC. Playing FF14 if i have it on DX11 at some point within the first 30 mins pc will lose power and restart. No event logs other than unexpected shutdown at X time. From googling other people with really similar or the same hardware had either crashes or the exact same behaviour. Been playing it on DX9 instead and had no issues other than a random crash streaming it on discord, which gave me an error no power loss.
Last night however it cut power, rebooted even though i was running DX9, no event logs nothing. My specs are below, but i had a similar issue when i got the 6900xt, the cables in the case were pushing the card ever so slightly out of the slot and when running hashcat at some point it would do the same behaviour however i had to remove the power cable and hold the power button down before it would power on again.
I have taken the card out again, moved any cables that could interfere with the card hoping this will solve the issue.
Just wanted a sanity check, there is no way a software crash could cause a power cycle in this manor right? surely it would put something in event log, crash to desktop or bluescreen rather than cut power and reboot.
Secondly, are Corsair power supplies interchangeable? I have a corsair HX1000i if i bought a new one could i just swap the power supply itself rather than having to swap all the cables in the case.
Ryzen 3900x
Asus WS X570-ACE
32gb Kingston Hyperx (2x HX432C16PB3K2/16)
XFX 6900xt merc
Corsair Hx1000i
Edit: Other than the issues with hashcat when i first installed the card, no other games have crashed or had any issues. Just FF14 this last week, been playing valorant, R6 siege zero issues. I can run hashcat as well, the same load that caused the original crashes, no problems
Ryzen 3900x
Asus WS X570-ACE
XFX 6900xt merc
Corsair Hx1000i
